Navigate menu options
Hello, I have to navigate the menu options using k6 browser module using JS. How to do it?
How can I click on the menu title and choose any menu option.
example:
Animals // let’s call it as title
Cat //option 1
Dog //option2
now I need to write the JS code for navigating to Animals and then click on Dog. How should I do it using k6 browser module?
Hi @chaitanya6,
Please send us a simple HTML page and your script. So we can help figure out the problem.
Since you want to select a menu option, you can use the following API call:
// 1. change selector to your menu item ID or XPATH.
// 2. change values to what you want to select.
page.selectOption(selector, values);
For getting started with browser tests, please take a look this guide.
Thanks.
