I’m trying to use URL Login with my JWT token generated by node jsonwebtoken package to embed a grafana panel into my webapp
this is my token payload:
{ "sub": 10, "userData": { "email": "[email]", "group": 1, "firstname": "Daniel", "lastname": "[lastname]" }, "iat": 1731311279, "exp": 1731314879 }
I’ve set the following in my grafana.ini:
`[security]
allow_embedding = true # Allow embedding
[auth.jwt]
url_login = true # enable JWT authentication in the URL
enabled = true
key_file = /etc/grafana/jwt_pub.key
url_parameter_name = auth_token
email_claim = userData.email
username_claim = userData.email
auto_sign_up = true`
However trying to embed a panel only leads me to the login page, any ideas what might be the issue?
11.3 on Arch Linux -
What happened?
I’m getting redirected to Login page instead of getting displayed a Panel Embed -
Seeing the Panel Embed cause the JWT token was present in the &auth_token parameter -
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly
No, only log I could find which might be related is: grafana-1 | logger=context userId=0 orgId=0 uname= t=2024-11-11T08:29:38.185398063Z level=debug msg=“Failed to authenticate user in global scope” error=“[auth.identity.unsupported] invalid identity type”
Also, if you only have an idea how to debug the issue, I’ll be very glad ![]()
