Hi team!
Im trying to use jsonwebtoken library with webpack 5 but it doesn’t seem to be working. After configuring webpack config I was able to build the bundle and just importing this import jwt from 'jsonwebtoken'; works fine.
even so when I try to execute the bundle I get this error when I use jwt.sign function inside the script:
➜ k6-template-es6 git:(main) ✗ ./k6 run dist/faker-test.js
/ __________ \ |__| \__\ \_____/ .io
execution: local
script: dist/faker-test.js
output: -
scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
* default: 1 iterations for each of 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
ERRO[0000] TypeError: Value is not an object: undefined
I have use this repo as base to do this POC → GitHub - grafana/k6-template-es6: Template using Webpack and Babel to enable ES6 features in k6 tests
This is the test script:
const TEST_JWT_KEY = {
algorithm: 'ES256',
issuer: 'test',
pkcs8: '-----BEGIN PRIVATE KEY-----\nsome_key\n-----END PRIVATE KEY-----\n',
const userData = {
iss: TEST_JWT_KEY.issuer,
'srt:driver_id': 12345,
iat: Date.now(),
function generateJWT(payload) {
const privateKey = TEST_JWT_KEY.pkcs8;
const algorithm = TEST_JWT_KEY.algorithm;
const token = jwt.sign(payload, privateKey, { algorithm: 'ES256' });
return token;
export default function () {
const token = generateJWT(userData);
console.log(token)
This is my webpack config just in case :
var webpack = require("webpack");
const { CleanWebpackPlugin } = require("clean-webpack-plugin");
var path = require("path");
const GlobEntries = require("webpack-glob-entries");
module.exports = {
mode: "production",
entry: GlobEntries("./src/*-test.js"), // Generates multiple entry for each test
output: {
path: path.resolve(__dirname, "dist"),
libraryTarget: "commonjs",
filename: "[name].js",
module: {
rules: [
test: /\.js$/,
loader: "babel-loader",
// by default, it resolves `node_modules`
stats: {
colors: true,
plugins: [
new CleanWebpackPlugin(),
new webpack.ProvidePlugin({
process: "process/browser",
Buffer: ['buffer', 'Buffer'],
externals: /^(k6|https?\:\/\/)(\/.*)?/,
resolve: {
fallback: {
buffer: require.resolve("buffer/"),
crypto: require.resolve("crypto-browserify"),
stream: require.resolve("stream-browserify"),
util: require.resolve("util/"),
process: require.resolve("process"),
buffer: require.resolve('buffer/'),
Any idea about what is going on?
Thanks in advance!
