Faker in K6 by bundling with webpack
I am trying to use faker by bundling with webpack but I am not able to use it. I am getting the following errors “No Schema”. more details in the image below.
I have refer this link Performance Testing with Generated Data using k6 and Faker - DEV Community
Hi @Palman,
As far I can see you probably just run your original file instead of the one webpack created for you, which would be found in dist/test.main.js or something similar.
I just followed the instructions with the provided repo and it worked perfectly although I did just run yarn pretest && yarn test instead of running k6 directly.
Thank you for the quick response.
it works.
