Json request via url with infinity plugin
Hi there im trying to integrate Acronis Cyber protect platform reports to grafana via json call.
the command is
GET /api/am/api/1/playbook/call/summary_alert_table?from=$last_30_days&limit=10&utc=2
And returns values but in one line with pointer data
[{“activity_type”:“infrastructure”,“resource_name”:…}]
“series”: [
“data”: [
“activity_type”: “infrastructure”,
“resource_name”: “genper”,
“resource_type”: “machine”,
“severity”: “warning”,
If i take it with inline method and remove these pointer works
“series”: [
“data”:
But this makes the report static and not refreshable
could you please advise?
I would also try this similar plugin and see if you have more luck destructuring the data:
