When trying to create a Datasource using the JSON API Plugin I get an error saying “JSON API: Not found”. The URL works in browser, other URLs have been configured as datasource without any problem. Does anybody know why that could be?
Grafana Version: 7.5.7
OS: Alpine 3.10
Adding a JSON API datasource using
https://my.url.de/icingaweb2/reporting/report/download?type=json&id=5
What happened?
Error “JSON API: not found”
It’s hard to say why this isn’t working. Is the API endpoint that you are hitting a public one? If we could test it then we could try and help you troubleshoot it. The creator of that plugin is a Grafana employee and actively maintains that project.
APIMOCk: https://6204e186161670001741afee.mockapi.io/netbox
grafana log:
grafana_1 | t=2022-02-11T04:20:29+0000 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/api/extras/scripts/firsttest.MyScript/ status=404 remote_addr=10.18.32.82 time_ms=3 size=29 referer=http://10.2.76.63:3000/datasources/edit/YbxdNP-nz
grafana_1 | t=2022-02-11T04:20:41+0000 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/api/extras/scripts/firsttest.MyScript/ status=404 remote_addr=10.18.32.82 time_ms=3 size=29 referer=http://10.2.76.63:3000/datasources/edit/YbxdNP-nz
Same problem out of the blue sometime it works
my doubt is this remote_addr being pointed to different address why
