9.5.2 -
Trying to connect json api datasource -
Fill in the URL of json api URL and skip tls verify -
What happened?
Replied with 504 error from log files, but curled looks good:
[obs_logmo_prod@vshgms103 (prod) log]$ time curl -k -I https://10.17.28.7:10000/api/v1/cmdb/hosts
HTTP/1.1 200 OK
Server: Werkzeug/2.1.2 Python/3.9.16
Date: Fri, 10 Nov 2023 01:54:30 GMT
Content-Type: application/json
Content-Length: 271218
Connection: close
real 0m0.026s
user 0m0.011s
sys 0m0.002s
Connection could be set up successfully -
In defaults.ini, I set the dialTimeout and tls_handshake_timeout_seconds as 30s. -
And from grafan.log:
logger=data-proxy-log userId=2 orgId=1 uname=dujas path=/api/datasources/proxy/uid/f3f4e572-619c-48f0-85b8-9697a220633f remote_addr=10.17.41.198 referer=https://obs.ai.ms.com.cn/datasources/edit/f3f4e572-619c-48f0-85b8-9697a220633f t=2023-11-10T09:47:02.966160926+08:00 level=error msg="Proxy request timed out" err="net/http: TLS handshake timeout"
logger=context userId=2 orgId=1 uname=dujas t=2023-11-10T09:47:02.966289004+08:00 level=error msg="Request Completed" method=GET path=/api/datasources/proxy/uid/f3f4e572-619c-48f0-85b8-9697a220633f status=504 remote_addr=10.17.41.198 time_ms=30006 duration=30.006467657s size=0 referer=https://obs.ai.ms.com.cn/datasources/edit/f3f4e572-619c-48f0-85b8-9697a220633f handler=/api/datasources/proxy/uid/:uid
- Did you follow any online instructions? If so, what is the URL?
Configure Grafana | Grafana documentation
