v8.0.2 (5c5d45e19f)
- What are you trying to achieve?
I’m trying to create a Mixed datasource that contains 2 queries.
- Query1 (1 row with the date I need)
- Query 2 (multiple rows with the data I need)
Query1 example (1 row with columns):
app; date
“test”; "“20221007”
Query2 example (multiple rows).
app; date; dataset
“my-app”; "“20221007”; “data1”
“my-app”; "“20221007”; “data2”
“my-app”; "“20221007”; “data3”
“my-app”; "“20221006”; “data1”
“my-app”; "“20221006”; “data2”
My goal is to join these 2 queries by “date” and obtain:
app; date; dataset
- How are you trying to achieve it?
Im trying to use an “outer join” transformation by date (but it only keeps one of the records from Query2
I’ve also tried a Merge, but then I’m not sure how to filter by the date “20221007” without having to provide this specific date manually. The date from Query1 will change daily
