Issue with Bar Charts Not Rendering in Grafana Dashboard
Dear community,
I hope you’re all doing well.
I’m experiencing an issue with my Grafana dashboard, which consists of 5 rows and 34 panels, each displaying a Bar Chart.
However, some panels (with no identifiable pattern) fail to render the chart when I first open the dashboard. The only way to restore the visualization is to:
  1. Enter edit mode on one of the blank panels.
  2. Switch to table view (where the data is correctly displayed in table format).
  3. Switch back to chart view, at which point the Bar Chart appears as expected.
I’m working on Grafana Cloud at an enterprise level, using VictoriaMetrics as the database.
Has anyone encountered this issue before, or do you have any suggestions on how to fix it?
Many thanks for your support!
Take care,
A.
Hi @Att
If you haven’t already done so, please open a support ticket from your account portal so the team can review this more closely.
Be sure to include any screenshots or error messages that will help them understand what you’re seeing.
And if you’re able to identify the issue with the support team, please share the resolution here for anyone else who might have a similar question in the future!
i’m facing the same issue, any news ?
Same issue here. It’s been six months now so it would seem this issue has been overlooked.
