Grafana is running in kubernetes -
We have two keycloak groups for which we need to give admin role in grafana -
We have used below configuration in grafana oauth plugin
“contains(groups[], ‘devops-Members’, ‘support-Members’) && ‘Admin’ || contains(groups[], ‘IT-Members’) && ‘Editor’ || ‘Viewer’”
What happened?
It did not work for support-Member group with admin role. Got below error log
incorrect number of args"
t=2021-10-17T05:33:45+0000 lvl=eror msg=“Failed to extract role” logger=oauth.generic_oauth error=“failed to search user info JSON response with provided path: “contains(groups[], ‘devops-Members’, ‘support-Members’) && ‘Admin’ || contains(groups[], ‘IT-Members’) && ‘Editor’ || ‘Viewer’”: incorrect number of args” -
support-Members group(along with devops-Members group) should have admin access in grafana
Done -
Shared the error log in above query -
I didn’t find any proper solution url for this error
