Issue when stacking time series with mixed datasource (Grafana version 9.1)
    Grafana version 9.1 OS: Redhat linux 8.4
    Correctly stack time series from different datasources.
    I have 2 queries. One is a openTSDB query, and the other one is a PNP.
    In time series options, I use the stack option in Normal.
  • What happened?
    Opentsdb has a donwsample of 5 minutes. PNP has a downsample of 5 minutes too, but the time series shows values per minute, repeating values, since it only changes every five 5 minutes.
    Screenshot from 2024-03-25 16-01-34
    I have this same query in Grafana 6.7, both datasources are the same and time series are stacked together correctly.
    If you need any settings, please let me know.
    No errors shown.
    I found no instructions for issues like this.
can you show a table view of your data?
Hi, sorry for the delay, Here a attach in table format.
For queries taken from the openTSDB, I have values every 5 min:
And for PNP, as i said before, it shows values per minute:
Please let me know if you need anything else. Thanks.
can you try add a concatenate transform?
before:
after:
Thanks, it looks like the graph is fine now. The only issue is that i am getting the “data outside time range” message. I am trying to figure it out
Let me know if you found a similar message like this before. Regards.
