grafana-11.6.1-1.x86_64 on RHEL -
Install any plugin -
grafana-cli plugins install grafana-image-renderer -
What happened?
I expect plugin to be installed like on old 9.x machine -
Nothing in logs -
N/aA
Traffic is proxied and connection to internet available. curl https://grafana.com/api/plugins/oncall-app/versions returns
