Hi everyone I was wondering if this graph is possible to be made in grafana.
Could you be more specific about your question/objective? Are you asking if it’s possible to use Grafana to create a chart that looks something like this one, or are you asking whether Grafana was used to create this specific chart?
Hi svetb my apologies. I was wondering if it’s possible to use Grafana to create a chart that looks something like this one.
Got it. In that case I’d say the answer is yes - you should definitely be able to create something like this
Is there any guides on how to include multiple lines in one graph? I feel like grafana documentation is lacking or my googling isnt enough.
Maybe Time series dimensions | Grafana Labs is helpful? But again, hard to say more without any context.
Could you tell us about your data source, data schema/format? Also which documentation you’ve followed so far, what you’ve tried, and where you’ve got to?
