Actually i have a application named “Transmission” i want to monitor this application. Is there any way to monitor the application ?
This is a question about your application, far more than it is about Grafana.
Ask yourself the following questions:
What does Transmission do?
How can you tell whether it’s doing what it should?
How can you tell whether it’s not doing what it should?
The answers to (2) and (3) should be in the form of something that can run on
the same machine, or across a network, and find out whether Transmission is
healthy or not.
Then you can start thinking about the Grafana side of things, because you
then know what it is you are going to measure / monitor.
Antony.
