Is there any limitation in adding multiple Tags in Field Mappings for a Grafana dashboard, when using Data Source: ES Logs?
Grafana v10.1.2
    Defining multiple Tags in Field Mappings for a Grafana dashboard, when using Source Type: ES Logs
Deploying them manually as in the screenshot:
  • What happened?
When adding only one tag, for example “service” it shows correctly under the annotation:
But when adding more tags, such as: service, environment is not showing anything:
To be able to add multiple Tags and visualize them into the annotation.
It’s a manual configuration, screenshot attached above.
Yes, following Grafana official doc regarding multiple tags. Is written is possible, but example is only for Data Source: Grafana, not including Data Source: ES Logs
