Is there an SMTP server installed in the Grafana Docker container?
Dear all,
I have a simple question regarding the Grafana Docker image available at Docker Hub
Is there an SMTP server already installed in this container ? I switched the GF_SMTP_ENABLED variable to “True” on Rancher, but now Grafana complains there is no SMTP server listening on localhost:25.
What am I doing wrong ? Should I instantiate a new “SMTP” container for this purpose ?
Best regards,
Samuel
Did you launch your container as :
docker run
-d
-p 3000:3000
–name grafana
-e “GF_SMTP_ENABLED=true”
-e “GF_SMTP_HOST=smtp.example.com”
-e “GF_SMTP_USER=myuser”
-e “GF_SMTP_PASSWORD=mysecret”
grafana/grafana:5.1.0
Check this thread :
Good Luck
Dear @wlargou
Thanks for your quick reply :slight_smile:
I left GF_SMTP_HOST blank, hoping there would be an SMTP server already listening locally on port 25, as per this documentation:
One of my colleague told me it used to work without any further configuration (i.e no need to use an external SMTP server).
I just checked the Dockerfile on Github but there doesn’t seem to be any SMTP server installed, and port 25 is not exposed (only port 3000):
Would you recommend using an external SMTP server ?
Best regards,
Samuel
Yes as a matter of fact you can either use your existing SMTP or create a new one, SMTP duties are sending/receiving emails, as a design rule you should separate this duties from Grafana.
Goof Luck
