Grafana 8.5.5 (docker) on a Debian 11 machine
Enabling the docker container to send emails from the localhost without a relay or other SMTP server (such as Gmail).
Setting GF_SMTP_HOST=localhost:25 to my machine’s IP with port 25
What happened?
The container is blocked. When attempting to send a test alert, I get a 127.0.0.1:25 connection refused.
This may have to do with my very strict firewall that only allows access to port 22 from the outside for security reasons. However, it seems the request does not even reach the firewall at least from what I could see in its logs.
I suspect that the container either uses its own localhost in the first case which does not have postfix or cannot be forwarded to the host by docker since it is not in the host network, or is blocked by the firewall in the second case.
The mail is sent using the machine’s postfix config, similar to what happens when I use sendmail on the host directly.
GF_SMTP_HOST=???:25
Did you receive any errors in the Grafana UI or related logs? If so, please tell us exactly what they were.
In the UI:
Failed to send test alert.: Failed to send notification to email addresses: target@example.com: dial tcp {127.0.0.1,<host-ip>}:25: connect: connection refused
In the logs:
grafana_1 | logger=alerting.notifier.email level=error msg="Missing receiver"
grafana_1 | logger=alerting.notifier.email level=error msg="Missing group labels"
grafana_1 | logger=context traceID=00000000000000000000000000000000 userId=2 orgId=1 uname=<uid> t=<time> lvl=info msg="Request Completed" method=POST path=/api/alertmanager/grafana/config/api/v1/receivers/test status=207 remote_addr=<host-ip> time_ms=5 duration=5.698845ms size=477 referer="https://myhost.example.com/alerting/notifications/receivers/contacts/edit?alertmanager=grafana" traceID=00000000000000000000000000000000
N/A
