Is there a way to insert a newline into a table header cell?
I’m using a table panel to display information, nothing serious, just numerical information. As I have 12 columns, in the table, I have a shortage of horizontal space. So, I’d like to change header cells like “Warmup [kWh]” into “Warmup <br/>[kWh]”. Unfortunately, when I insert the <br> tag into the Column Header (Column Style tab of the Table panel), it is displayed litterally in the header cell.
Is there a way to work around this and have a newline in the header cell ?
By the way, is it possible to align numerical values right ? Right alignment should be standard for numbers. Now the standard alignment is left.
Stefaan
no there is no way to do that
Are you planning to export the table header?
