What Grafana version and what operating system are you using? - 10.0 OSS
I would like to provision Users through the API, however setting them to be Okta enabled. Currently an account is created when a user hits the service, however I then need to assign them to the correct Org/Team etc. -
Through the API -
What happened?
It does not set the authLabels section, either on create or update user -
Create a User that is expected to be authenticated through Okta -
Nothing to really paste -
Not that I can see -
User HTTP API | Grafana documentationq
