Is there a way to change x-axis time precision to microseconds for influxdb?
I am working on using influxdb/grafana for a industry monitor system, everything works fine if the sensor data sampling interval is bigger than 1ms.
For some systems, it requires the sensor data sampling interval to be 100us.
To visualize the sensor data in grafana in microseconds precision, is there any way I could use?
Or if I put the microseconds timestamp as the field data in influxdb, can I replace the x-axis with this timestamp field data for visualization in grafana?
Thanks.
please edit your question and come back wfen you transformed into an understandable format
Hi, could you please share me the definition of the “understandable format”?
Then I could refine my question.
Thanks.
yes sure,please have a look here
Melrose, you seem to be specialising in unhelpful (bordering on rude) replies
either to people who are not native English speakers, or where you simply did
not understand the question, even when it appears perfectly clear to me (for
example).
What was not clear to you about the original questions in this thread:
"To visualize the sensor data in grafana in microseconds precision, is there
grafana?"
Regards,
Antony.
if it is so clear and you could understand it please feel free to answer it. I couldnt.
I did not answer it simply because I do not know the answer.
That is entirely different from complaining to the questioner that their
language is not clear, and then directing them to an enormous wikipaedia
article of dubious relevance to the phrasing of their question.
If you cannot answer a question, the best response is often not to respond.
Antony.
@qzheng527 i had this request too. This is currently not possible you have to wait a while https://github.com/grafana/grafana/issues/27848
