Grafana Version: 11.0.0
O/S: Ubuntu or MacOS -
I’m trying to remove/disable time options from the date/time picker (i.e. last 7 days) -
I tried updating the json model, by adding an empty time_options array. -
What happened?
Time picker options were not removed. -
Time picker options were removed. -
“timepicker”: {
“hidden”: false,
“time_options”: [
“30d”
“type”: “timepicker”
No errors. -
N/A
It is possible to modify XXXX.yyyyyyyyyyyyyyyyyyyy.js file in public/build folder that contains this list (for example, 4570.87a4acc6d9144f9ee50a.js for Grafana 11.0.0).
Search for the following text and remove periods that you don’t need.
const t=[{from:"now-5m",to:"now",display:"Last 5 minutes"},{from:"now-15m",to:"now",display:"Last 15 minutes"},{from:"now-30m",to:"now",display:"Last 30 minutes"},{from:"now-1h",to:"now",display:"Last 1 hour"},{from:"now-3h",to:"now",display:"Last 3 hours"},{from:"now-6h",to:"now",display:"Last 6 hours"},{from:"now-12h",to:"now",display:"Last 12 hours"},{from:"now-24h",to:"now",display:"Last 24 hours"},{from:"now-2d",to:"now",display:"Last 2 days"}...
Or modify source code and compile custom Grafana version
