Is it possible to do a "replay" or "fast forward" of a dashboard?
Hi, I’m a total newbie to this site, and have only been using Grafana for a couple months for a personal project.
I’m hoping that there is some way that I can generate some sort of time-lapse view of my dashboard for demos or videos. I know that I could use the single-step forward or backward shortcuts, but I would REALLY like to be able to play back a 24 hour period quickly and smoothly, as if there was a screen capturing utility taking a snapshot every minute, then playing those snapshots back at 30 frames per second.
Is there a good way to do that, or will it require a brute-force approach?
Nothing Grafana supports. Guess you’re on your own here. But doesn’t just changing the time range to 24 hours for example give you all data that you want?
Marcus
