Is it possible to devise dashboard variables from log data?
Grafana Cloud v9.2
Add dashboard variables based on the data being displayed.
I have a dashboard displaying logs from our server. These logs include the domain name used when accessing the server, so we can see which tenant of the system is seeing any errors. It also displays the all the log lines
The graph of errors displays error count, per tenant, but is it possible to add dashboard variables based on the currently displayed log errors, so that we can drill down to display only errors for a given tenant, without knowing the list of tenants ahead of time?
Somehow query for the variable values within the log data
What happened?
n/a
n/a
n/a
n/a
I couldn’t find any documentation on this topic specifically.
