Is it possible to capture a string with a space in it?
Hi
Is it possible to capture a string with a space in it? I am parsing the log for labels, because it is crooked in the source without labels. I use pattern. Cannot capture date and time in one tag
Example Log
INFO: GeoBlock: 2023/06/04 08:25:30 geoblock@file: request denied [183.136.225.45] for country [CN]
Query
sum by (message, country, date, time, ip) (rate({container_name="traefik"} | logfmt | __error__=`` | pattern `<_>: <_>: <date> <time> <_>: <message> [<ip>] <_> [<country>]` [$__range]))
Hi @
pavelnarozhny88,
Thanks for opening this issue.
Please review the submission template and include more details:
  • What is your datasource?
  • What visualization panel you are using e.g. time-series, bar chart, histogram etc?
  • What happened?
I’m trying to combine date and time into one column in the table. So that the filtering by columns works properly.
I pull logs from the docker, there is a log that can not be pulled normally without pattern
Thanks,
I think this seems more like Loki LogQL related question.
I am not the best guy to help with the Loki stuff. So I will move this post to the correct category so that the folks there can help you out.
Also, we do have LogQL documentation page where some examples are available. Maybe there are some tips regarding so please check it out as well.
I read the instructions. It does not contain the right example
You can use pattern and then combine datestamp and timestamp with line_format. I have an example on your other posts that you can reference to.
However, I would say that in general you should not have to or want to parse log lines for time stamps. You should be doing that during log ingestion, so that the logs are stored on Loki with the correct time stamp matching that of the log lines.
Example please
The table does not have a time parameter. More precisely, there is, but it transmits the current local time
So it didn’t work
sum by(date, time, message, country, request_addr) (rate({container_name="traefik"} | logfmt | line_format "{{.date}} {{.time}}" | __error__=`` |~ `$geoblock` | pattern `<_>: <_>: <date> <time> <_>: <message> [<request_addr>] <_> [<country>]` [$__range]))
| pattern "<_> <_> <date> <time>" | line_format "{{.date}}-{{.time}} {{__line__}}"
Your log line becomes:
2023/06/04-08:25:30 geoblock@file: request denied [183.136.225.45] for country [CN] INFO: GeoBlock: 2023/06/04 08:25:30 geoblock@file: request denied [183.136.225.45] for country [CN]
Again, this is not how you should do it. See my other reply below.
That’s what I was referring to in my original post. You should parse your logline and change the timestamp to that instead of using local time of your log agent. I don’t know what log agent you use, but a generic flow should be something like this:
  1. Given log line:
  1. Parse it (however your log agent does it) and get the date and time (2023/06/04 08:25:30).
  2. Set the log line timestamp to 2023/06/04 08:25:30.
  3. Forward to Loki.
Is there an example of how to use it? I can’t analyze the log properly
:frowning:
Using your original log line, assuming you are using promtail:
Promtail pipeline stage;
pipeline_stages:
  - regex:
      expression: '^(?:\S+): (?:\S+): (?P<timestamp>\S+ \S+) (?:.*)'
  - timestamp:
      source: timestamp
      format: '2006/02/01 15:04:05'
Ty!
Made it like this
