Is it just system monitoring?
I have some raw fiance data, as well as inventory, I asked around on another forum what would be the best way to display all my information, and Grafana came up.
All the examples I’ve seen are just CPU used, network bandwidth and so on.
Is it completely customisable?
You can display anything in Grafana which you can get into your data store.
Antony.
Grafana can visualize anything, but it is especially good with data that changes over time, if you need to monitor the stock market value of some action, grafana will be good, if you want to see in semi-real time the sales of your grafana team would be ideal ,
but grafana is not oriented to BI, so you will find limitations in some occasions to make graphs of these techniques, such as seeing sales grouped / summarized by more than one variable.
You could also look at these:
