Hello:
I hope this query finds you well.
I want to integrate EC2 information into my Promtail Jobs. I am following the tutorial at https://grafana.com/docs/loki/latest/clients/aws/ec2/.
I don’t see even a crumb of EC2 information when I examine the logs in Grafana, particularly not in the “Edit Panel” UI’s “Log labels” tree-menu. Too, I confirmed that new log entries are indeed reaching Grafana.
Neither my Promtail log nor my Loki log contain any error entries (and the Promtail log contains only one reference to EC2, while in debug mode).
Here is my redacted promtail-local-config.yaml:
server:
http_listen_port: 41000
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
scrape_configs:
- job_name: system
static_configs:
- targets:
- localhost
labels:
job: varlogs
__path__: /var/log/*log
- job_name: journal
journal:
json: false
max_age: 12h
path: /var/log/journal
labels:
job: systemd-journal
relabel_configs:
- source_labels: ['__journal__systemd_unit']
target_label: 'unit'
- job_name: ec2-logs
ec2_sd_configs:
- region: us-moon-1
access_key: AKIAFFFFFFFFFFFF
secret_key: ***************************************
relabel_configs:
- source_labels: [__meta_ec2_tag_Name]
target_label: name
action: replace
- source_labels: [__meta_ec2_instance_id]
target_label: instance
action: replace
- source_labels: [__meta_ec2_availability_zone]
target_label: zone
action: replace
- action: replace
replacement: /var/log/**.log
target_label: __path__
- source_labels: [__meta_ec2_private_dns_name]
regex: "(.*)"
target_label: __host__
clients:
- url: "http://172.3.4.5:5000/loki/api/v1/push"
Even if I should completely discarding this tutorial, how can I integrate EC2 information into my Promtail Jobs?
Graffana
PS: I searched elsewhere at length and could not find a treatment.
