I just migrate to Grafana 2.7 and now use fluxql instead of influx.
I have problem with my integration table. I use a light sensor calculating PPFD.
See image here:
IN left side you have light PPFD for each day. What I want in the right is the integration of each 24h time 00h00 to 23h59.
I must have 1 table line per day.
ANy hints how I can achieve this?
My actual flux query is this:
from(bucket: “borealis”)
|> filter(fn: (r) => r[“_measurement”] == “borealis”)
|> filter(fn: (r) => r[“_field”] == “LIGHT”)
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: “mean”)
|> integral(unit: 24h, column: “_value”)
