Installing loki docker plugin using ansible = error
Hi
I have been trying to install loki docker plugin using ansible playbook.
Ansible has this function to install plugins:
    - name: Install Loki Docker Driver
      community.docker.docker_plugin:
        plugin_name: grafana/loki-docker-driver:latest
        alias: loki
        state: enable
In the loki plugin doc the command is:
docker plugin install grafana/loki-docker-driver:2.8.2 --alias loki --grant-all-permissions
There is a --grant-all-permissions flag that cannot be set when installing in ansible.
Is it a bug, missing functionality ?
Regards
According to docker_plugin add the ability to specify install options · Issue #145 · ansible-collections/community.docker · GitHub --grant-all-permissions is the default.
Thanks, @tonyswumac
Then there must be another reason why the plugin is not installed correctly.
