On our Kubernetes Cluster here (Version 1.14.2) I have installed the following:
- The Grafana Helm Chart (from here)
- The Grafana App For Kubernetes (the Grafana Kubernetes Plugin) (from here)
Using the Grafana Kubernetes Plugin I did “Add a new cluster”. I filled in certificate details as they were provided by the Kube Config file. I saved and the Kubernetes Plugin created also automatically a Grafana Data Source.
In the Grafana “Data Sources” section I did “Save & Test” for the automatically created Data Source. It shows “Data source is working”.
In Grafana I went into the automatically created “Cluster Dashboard” and none of the Graphs is working. There is a read “!” at the corner of each graph and on hovering it reads “Datasource named was not found”. That is the problem I have.
“kubectl logs grafana-7d56d6ff84-4sqlc” Shows no errors.
I appreciate any help!
