Install Grafana 11 with PostgreSQL on-premisses?
How to install Grafana 11 using the database with PostgreSQL on-premisses?
To install Grafana 11 with PostgreSQL as the database on-premises, you can follow these general steps. Note that the specific commands might vary slightly depending on your operating system and environment:
  1. Install Grafana:
  2. First, download and install Grafana. You can find the installation instructions for your specific operating system on the Grafana installation documentation.
  3. Set Up PostgreSQL:
  4. Ensure that PostgreSQL is installed and running on your server. You can download it from the official PostgreSQL website.
  5. Create a new database and user for Grafana. You can do this by connecting to your PostgreSQL instance and running the following commands: sql CREATE DATABASE grafana; CREATE USER grafana WITH ENCRYPTED PASSWORD 'yourpassword'; GRANT ALL PRIVILEGES ON DATABASE grafana TO grafana;
  6. Configure Grafana to Use PostgreSQL:
  7. Edit the grafana.ini configuration file, usually located in /etc/grafana/ or /usr/local/etc/grafana/.
  8. In the [database] section, configure the connection to your PostgreSQL database: ini [database] type = postgres host = localhost:5432 name = grafana user = grafana password = yourpassword
  9. Start Grafana:
  10. Start the Grafana server using the appropriate command for your system, such as systemctl start grafana-server on Linux.
  11. Access Grafana:
  12. Open a web browser and go to http://localhost:3000 (or the appropriate IP address if accessing remotely).
  13. Log in with the default credentials (admin/admin) and change the password when prompted.
  14. Add PostgreSQL as a Data Source:
  15. Once logged in, navigate to Configuration > Data Sources.
  16. Click Add data source and select PostgreSQL.
  17. Fill in the connection details for your PostgreSQL instance and save the data source.
By following these steps, you should be able to set up Grafana 11 with PostgreSQL as the database on-premises. If you encounter any issues, feel free to ask for further assistance!
xoxo Grot
grot is still learning and improving, please let me know how I did by reacting below.
👍🏽 or 👎🏽
Can you detail how to install Grafana 11 on premisses?
Certainly! Here's a more detailed guide on how to install Grafana 11 on-premises using PostgreSQL as the database:
Step 1: Install Grafana
  1. Download Grafana:
  2. Visit the Grafana download page and select the appropriate package for your operating system (Linux, Windows, macOS).
  3. Install Grafana:
  4. Linux (Debian/Ubuntu): bash sudo apt-get install -y apt-transport-https sudo apt-get install -y software-properties-common wget wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add - echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list sudo apt-get update sudo apt-get install grafana
  5. Windows:
    • Download the Windows installer and run it.
  6. macOS:
    • Use Homebrew: brew install grafana
Step 2: Set Up PostgreSQL
  1. Install PostgreSQL:
  2. Follow the instructions on the PostgreSQL website to install PostgreSQL on your system.
  3. Create Database and User:
  4. Connect to your PostgreSQL instance and run the following SQL commands: sql CREATE DATABASE grafana; CREATE USER grafana WITH ENCRYPTED PASSWORD 'yourpassword'; GRANT ALL PRIVILEGES ON DATABASE grafana TO grafana;
Step 3: Configure Grafana to Use PostgreSQL
  1. Edit the grafana.ini File:
  2. Locate the grafana.ini file, typically found in /etc/grafana/ or /usr/local/etc/grafana/.
  3. Modify the [database] section to connect to your PostgreSQL database: ini [database] type = postgres host = localhost:5432 name = grafana user = grafana password = yourpassword
Step 4: Start Grafana
  1. Start the Grafana Server:
  2. Linux: bash sudo systemctl start grafana-server sudo systemctl enable grafana-server
  3. Windows/macOS:
    • Use the appropriate service management commands or start the application directly.
Step 5: Access Grafana
  1. Open Grafana in a Browser:
  2. Navigate to http://localhost:3000 (or your server's IP address) in a web browser.
Step 6: Add PostgreSQL as a Data Source
  1. Configure Data Source:
  2. Once logged in, go to Configuration > Data Sources.
  3. Click Add data source and select PostgreSQL.
  4. Enter the connection details for your PostgreSQL instance and save the data source.
By following these steps, you should have Grafana 11 installed and configured to use PostgreSQL on-premises. If you run into any issues or need further assistance, feel free to ask!
xoxo Grot
👍🏽 or 👎🏽
