I have kubernetes cluster with successful installed grafana, Prometheus, loki. I have successfully installed on linux node alloy but unable to window node.
Kindly help me to troubleshoot this issue.
Thanks
Thanks
Hi @biswajitsahu357,
Can you share the steps that you are using for installation?
Hi, Please find the below steps , Which I did,
helm install --values lokis.yaml loki grafana/loki -n monitoring --create-namespace
helm install --values prom.yaml prometheus prometheus-community/kube-prometheus-stack -n monitoring --create-namespace
helm install --values alloy-linux.yaml alloy-linux grafana/alloy -n monitoring --create-namespace
helm install --values alloy-win.yaml alloy-windows grafana/alloy -n monitoring --create-namespace
I can see linux alloy is running as expected but windows is not, I am sharing the values.yaml for windows alloy, kindly help me to troubleshoot
alloy:
configMap:
content: |-
prometheus.exporter.windows "default" {
enabled_collectors = ["cpu", "logical_disk", "net", "os", "service", "system", "memory", "container", "textfile", "cpu_info", "process", "scheduled_task", "tcp"]
prometheus.scrape "example" {
targets = prometheus.exporter.windows.default.targets
forward_to = [prometheus.remote_write.demo.receiver]
prometheus.remote_write "demo" {
endpoint {
url = "http://prometheus-kube-prometheus-prometheus.monitoring:9090/api/v1/write"
loki.source.windowsevent "application" {
eventlog_name = "Application"
use_incoming_timestamp = true
forward_to = [loki.process.endpoint.receiver]
loki.source.windowsevent "System" {
eventlog_name = "System"
loki.process "endpoint" {
forward_to = [loki.write.endpoint.receiver]
stage.json {
expressions = {
message = "",
Overwritten = "",
source = "",
computer = "",
eventRecordID = "",
channel = "",
component_id = "",
execution_processId = "",
execution_processName = "",
stage.structured_metadata {
values = {
"eventRecordID" = "",
"channel" = "",
"component_id" = "",
"execution_processId" = "",
"execution_processName" = "",
stage.eventlogmessage {
source = "message"
overwrite_existing = true
stage.labels {
values = {
"service_name" = "source",
stage.output {
source = "message"
loki.write "endpoint" {
endpoint {
url ="http://loki-gateway.monitoring.svc.cluster.local/loki/api/v1/push"
livedebugging{}
image:
repository: grafana/alloy
tag: windowsservercore-ltsc2022
controller:
nodeSelector:
kubernetes.io/os: windows
Sorry for inconvience, Please check the link, where I take the reference, alloy-scenarios/windows/config.alloy at main · grafana/alloy-scenarios · GitHub
