I have an AKS cluster setup with 4 nodes (3 linux and one windows node). I deployed Alloy on linux nodes but it’s also reading logs from windows nodes. For this deployment i have daemonsets deployed on each of the linux nodes.
alloy:
configMap:
# -- Create a new ConfigMap for the config file.
create: true
# -- Content to assign to the new ConfigMap. This is passed into `tpl` allowing for templating from values.
content: |-
logging {
level = "info"
format = "logfmt"
discovery.kubernetes "kubernetes_pods" {
role = "pod"
discovery.relabel "kubernetes_pods" {
targets = discovery.kubernetes.kubernetes_pods.targets
rule {
source_labels = ["__meta_kubernetes_pod_controller_name"]
regex = "([0-9a-z-.]+?)(-[0-9a-f]{8,10})?"
target_label = "__tmp_controller_name"
rule {
source_labels = ["__meta_kubernetes_pod_label_app_kubernetes_io_name", "__meta_kubernetes_pod_label_app", "__tmp_controller_name", "__meta_kubernetes_pod_name"]
regex = "^;*([^;]+)(;.*)?$"
target_label = "app"
rule {
source_labels = ["__meta_kubernetes_pod_label_app_kubernetes_io_instance", "__meta_kubernetes_pod_label_instance"]
target_label = "instance"
rule {
source_labels = ["__meta_kubernetes_pod_label_app_kubernetes_io_component", "__meta_kubernetes_pod_label_component"]
target_label = "component"
rule {
source_labels = ["__meta_kubernetes_pod_node_name"]
target_label = "node_name"
rule {
source_labels = ["__meta_kubernetes_namespace"]
target_label = "namespace"
rule {
source_labels = ["namespace", "app"]
separator = "/"
target_label = "job"
rule {
source_labels = ["__meta_kubernetes_pod_name"]
target_label = "pod"
rule {
source_labels = ["__meta_kubernetes_pod_container_name"]
target_label = "container"
rule {
source_labels = ["__meta_kubernetes_pod_uid", "__meta_kubernetes_pod_container_name"]
separator = "/"
target_label = "__path__"
replacement = "/var/log/pods/*$1/*.log"
local.file_match "kubernetes_pods" {
path_targets = discovery.relabel.kubernetes_pods.output
loki.source.kubernetes "kubernetes_pods" {
forward_to = [loki.process.process.receiver]
loki.process "process" {
forward_to = [loki.write.loki.receiver]
loki.write "loki" {
endpoint {
url = "http://loki.loki.svc.cluster.local:3100/loki/api/v1/push"
This is my alloy configuration from helm values.yaml file.
I’m confused how are the windows pod logs accessible to alloy deployment on linux.
