I’m using Grafana with Loki as the data source to display logs in a table panel. However, JSON fields are not formatted correctly—they appear as a single string instead of being properly structured.
Someone can help me fix that?
here’s a screenshot and the panel.json file.
panel.json (5.9 KB)
ps I’m 100% sure that is a valid json. As you can see the code highlight works properly.
Any help would be really appreciated, thank you!
