Insert values from a SELECT query result inside a select with custom options form
Hi all, i’m on Grafana v10.2.0 with the data manipulation plugin made by Volkovlabs @mikhailvolkov .
I’m trying to insert the results from a query inside a form that have a cell with a “select with custom options”.
I would like to figure out how to avoid entering all the acronyms of the provinces by hand since there are hundreds of them.
the values (prov) and keys (common) that I would like to import are those extracted from this query
thanks in advance!
hi guys, have you ani solutions?
Can’t you use a variable to get all the acronyms?
select prov as __value, comune as __text from prov_comune_table
where should I enter this query?
Well is that prov comune data saved in a database? Or is it in csv or excel file
yes it is saved into a mysql db
Check this to find where to put it
I know how to use $_variables on grafana, but, do you think we can add the variable somewhere in the data manipulation plugin? if so where?
this documentation doesn’t treat this plugin
then this might help
@yosiasz @mikhailvolkov i’m trying to do my best following the guide but in this plugin there aren’t some options like this.
This is my plugin:
this is the guide plugin:
there isn’t the options source option in my plugin, but it’s the same
@nicolomenelle What is the version of the plugin you are using?
It should be one of the latest
@mikhailvolkov this is my current version of the plugin
i solved it, @mikhailvolkov @yosiasz thank you so much for the help :partying_face:, always very gently. this community is great!
with the new plugin 3.7:
