Hi
Is it possible to make ranges in grafana.
Input range: min 0 max 80%
New Output range: min 0 max 100%
Any example for this?
Tnx
Welcome @mojdiy to the Grafana forum.
AFAIK, this is not possible in Grafana. What datasource are you using? If you are using Node-RED to populate that database, why not use Node-RED to transform the data to the range that you desire?
