I have the following datasource.yaml to provision Grafana9.3.6 and InfluxDB 2.6.1 on Docker
apiVersion: 1
datasources:
- name: k6
type: influxdb
url: http://influxdb:8086
access: proxy
isDefault: true
orgId: 1
uid: z8DNrUAVz
jsonData:
version: Flux
defaultBucket: k6
organization: holoplot
tlsSkipVerify: true
secureJsonData:
token: MYTOKEN
But after launch, it shows unauthorized access error reading buckets. And on InfluxDB log it said Authorization not found.
However, in the same UI without relaunching, I can create a new datasource and manually adding exactly the same information and token. The connection worked.
Any suggestion why this might be ?
This is the docker compose
version: "3.7"
services:
influxdb:
image: influxdb:2.6.1
ports:
- 8086:8086
volumes:
- influxdb-storage:/var/lib/influxdb:rw
env_file:
- .env
entrypoint: ["./entrypoint.sh"]
grafana:
image: grafana/grafana:9.3.6
ports:
- 3000:3000
volumes:
- grafana-storage:/var/lib/grafana:rw
- ./grafana-provisioning/:/etc/grafana/provisioning:rw
depends_on:
- influxdb
volumes:
influxdb-storage:
grafana-storage:
grafana-provisioning folder consist of
- datasources/datasource.yaml
Environment: Docker
- Grafana version: 9.3.6
- Data source type & version: InfluxDB v2
- User OS & Browser: macOS M1, 12.6
