Grafana v11.6.0 in a Desktop Docker container on Windows
Backend is InfluxDB v3 Core -
Building a dashboard from data in databases of InfluxDB v3 Core -
Using builder to create a SQL Query that filters using “contains”
What happened?
Grafana fails to put double quotes around the column name in the SQL query, producing an error that it does not recognize the field name
I expected double quotes around the field name in the WHERE clause of the SQL query, which is what happens if you select == instead of “contains”. See what happens when you select == instead:
Above -
flightsql: rpc error: code = InvalidArgument desc = Error while planning query: Schema error: No field named devicename. Valid fields are presence.“deviceId”, presence.“deviceName”, presence.“hubName”, presence.time, presence.unit, presence.value, presence.“valueBinary”. -
No
