Hi!
Im trying to use pie charts with influxdb queries, and use a global_tag to graph.
For example,
host_type = testservers (included global_tags in telegraf conf)
My purpose:
To have a pie chart with server names that only include that tag.
Is it possible? How can I do this? is it necessary add another type of tag?
Im trying to search about but I only found with other databases.
Thanks!!
So you want to display a piechart split up on the tag host_type and the values for each slice will be number of servers belonging to/having that tag?
Marcus
I want to display the name of the host for each slice having that tag, for example:
hostname: test1 global_tag= test
hostname: test2 global_tag=test
In this case, choosing global_tag=test my pie should have one slice with test1 and another one with test2.
Is it possible?
thanks!!
I guess you need to group by hostname where global_tag=test, something like this:
SELECT count("value") FROM "<your measurement>" WHERE $timeFilter GROUP BY time($interval), "hostname"
Example in grafana:
Marcus
So, I see with your example that, you cant have any string in “your measurement”.
The only way to use it , it is with values.
I was thinking something like pie chart in kibana, I have one there in that way.
Thanks!!
As far as I know that isn’t possible.
I suggest you create a feature request issue here if this is something that you really want to have.
Marcus
