Influxdb datasource: how to reference max series?
    9.3.6
    Reference max series value in the provision json to set a higher value.
    In the datasource configmap I’ve set max_series: 5000 without success
  • What happened?
    The value hasn’t appeared in the config
    That the value be represented in the dashboard.
apiVersion: 1
datasources:
  - name: influxdb-ds
    type: influxdb
    access: proxy
    database:
    user: k6_user
    max_series: 5000
    url: http://influxdb-k6.monitor.svc.cluster.local:8086
    jsonData:
      version: Flux
      organization: influxdb-k6
      defaultBucket:  influxdb-k6
      httpMode: GET
      httpHeaderName1: Authorization
      httpHeaderName2: Content-type
    secureJsonData:
      httpHeaderValue1: 'Token __INFLUXDB_TOKEN__'
      httpHeaderValue2: 'application/json'
    results are truncated, max series reached (1000)
    I followed the influxdb datasource configuration url:
    InfluxDB data source | Grafana documentation
Ok, so the value that goes for max series is maxSeries and the value goes inside jsonData, like so:
