Infinity Filter by Datetime field
  • Grafana v10.4.0 (03f502a94d)
I wan to filter records from backend by field with Time format, is it possible?
I use Infinity datasource to receive JSON records with Time field (e.g "GenerationTime": "2022-12-28T11:32:04+06:00")
My backend can’t filter by time range itself. So I hope to filter records between $__from and $__to variable values with Grafana.
  • What happened?
Neither Infinity filter, nor Transformation “Filter data by values” doesn’t allow me to do this.
JSON sample: https://pastebin.com/raw/CnEsiG5N
I added JSON sample for tests on pastebin: https://pastebin.com/raw/CnEsiG5N
Correct UQL code for this code is:
parse-json
| where "GenerationTime" >= '${__from:date}'
Thx, @yosiasz
