Trying to filter unix time to current month only
Hello, I am using grafana cloud dashboards… I have a data series that I have pulled in via an API.
I am trying to find a way to filter the Unix Epoch time in the clientCreatedTime field so that my data set only shows the current month’s data (ie from the 1st of the current month → today inclusive).
Is there a way to do this using the transform options?
Thanks
Hi @markbull and welcome to the Grafana forum.
Does your table change at all when you select this in the time picker?
If not, it’s because Grafana does not “see” the clientCreatedTime field as the time field. If that’s the case, you should be able to use one of Grafana’s tools to change it. See some ideas here.
which plugin are you using to fetch the rest api data? infinity plugin or json api?
