Infinity Datasource with Json API call and Pagination
    • Grafana Cloud Instance
    • My current endpoint returns limited results, so trying to use Pagination.
    • I am using an Infinity datasource with an API call. I am trying to use a cursor type pagination with a replace URL option. I have a dashboard variable configured and set in the URL.
  • What happened?
    • I was expecting it to set that dashboard variable to the cursor value for subsequent runs. When it runs, it just runs my initial request multiple times and doesn’t perform the pagination.
    • I expected it to return the next set of results and not the same ones over and over
    • There are no errors whatsoever, however I can see that the same URL is being called multiple times, duplicating the existing data
Any help and guidance in getting this working correctly would be helpful. I have tried to modify my Extraction Path with multiple different variations of this format. I have even tested my path with online jsonpath testers to make sure that I am retrieving the correct value from my json.
Thank you.
Same here. Seems like it’s getting the value of Extraction path but not using it at next requests.
