mmm014
1
Hi, I am using Fiddler for my Web traffic monitoring then I exported it into HAR file.
But the HAR file size contains 26MB in size and k6 Cloud only supports 10MB.
I am needing to convert this 26MB HAR file size into k6.
Any workaround that I can try or other software I can use to decrease the size of a HAR file? Thanks!
Hi @mmm014!
Let me try to help you!
You can convert the HAR file of that size on your local machine using the HAR converter on your local machine.
Let me know if that helps,
Cheers!
mmm014
4
Hi @olegbespalov , thanks for replying to this inquiry. Will try this workaround and will update you right after. Hope it works
Thank you so so much!
