Importing and Exporting in FE (UI) and BE (API) unaligned
Hi @all!
It seems as if the (dashboard) export function of grafana differs between the backend API result and the frontend UI result.
It also seems as if an API exported dashboard is not made to be reimported (format differs).
Why is this as it is?
Should this not be aligned?
Should this not be mentioned in de documentation?
Greetings
Anthrax
