Import the inbuilt Heartbeat Kibana dashboard to Grafana
Hi Team,
I have a requirement wherein a team wanted to use Grafana with the templates i have created. They have been using Kibana extensively with heartbeat. Kibana provides a default/inbuilt dashboard for heartbeat. Is there a way i can replicate this Kibana dashboard to Grafana? I do understand that, i can recreate manually the panels by comparing with Kibana, however the Heartbeat dashboard does not expose any fields that can be seen. I searched the internet sources with no luck.
Any help/idea would be appreciated.
Any help/insights will be helpful please…
Heartbeat creates an index in Elasticsearch with the dashboard information (fields) so you can try to reproduce it testing the different fields.
