Simple new metricbeat - elastic cluster dashboard?
I’m pretty new to monitoring elastic with grafana, and monitoring overall. I’m also newbie in my job and my task is to setup Grafana for monitoring elastic. The reason is because we are moving to on-premise elastic, and it’s Kibana basic version doesn’t have alerting (or it’s complicated). We also want to add our kubernetes to grafana, so grafana will become our one place for dashboards and alerts. But right now, i’m unable to find good dashboard for metricbeat (they are probably old and metricbeat changed name of metrics), and also metricbeat is sending an awfull amount of data which i didnt find a way to reduce, so i wasnt able to make my own dashboard because of confusion in amount of metrics (and documentation, tbh). Do you know of any way how to proceed with this?
  • What Grafana version and what operating system are you using? - v11.5.2
  • What are you trying to achieve? - Get simple working metricbeat dashboard, or find most common metrics
  • How are you trying to achieve it? - I tried to install public dashboards, but non of them are working, or working only partly. Mostly metricbeat is using different name of metrics, and i am new to monitoring elastic with grafana
  • What happened? - No dashboards publicly available are working
  • What did you expect to happen? - Them to work
  • Can you copy/paste the configuration(s) that you are having problems with? - Tried different dashboards online
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. - In dashboard configuration, had error 400 or not available metrics
