I installed grafana v6.2.5 and I’m able to access it through the web gui.
I configured the Direct DB connection to my Zabbix MariaDB and it works.
I imported the Zabbix Plugin Config and seems to be well installed.
Now trying to import any Dashboard downloaded from the grafana Dashboard list I get the error:
“No data sources of type Zabbix found”
What should I do?
Thanks
Regards
Michele
