[Image-Renderer/S3] Grafana won't upload images to bucket/send images to slack using a webhook
Grafana v12.0.2, deployed via Helm chart grafana-9.2.9.
Running on Amazon Linux 2023 (Kubernetes pod).
Get alert images from Grafana to display in Slack messages.
  • Using the Grafana Image Renderer sidecar pod.
  • Tested both Slack contact point modes:
    1. Incoming Webhook + external image storage on AWS S3.
    2. Slack bot token (xoxb…) with “Upload image” enabled.
What happened?
  1. Rendering works fine (curl /render/d-solo/... produces PNGs).
  2. In webhook mode, images are uploaded to S3 successfully, but with no consistency, which means they occasionally fail to upload and Slack shows no image.
    Here’s what I tried:
    • Configuring our S3 buckets to block all public access and allow access to Grafana’s K8S Service Account via an IAM role only (org policy).
    • Enabling full public access to the bucket (Still very flaky, sometimes it would work, but with no consistency.
    • Slack can’t fetch the image URL Grafana provides.
  3. In bot token mode: images do get uploaded to Slack, but they appear as threaded replies, not inline with the alert message.
  4. Logs showed a lot of renderer noise at first (timeouts, timezone errors, Prometheus query failures), but I confirmed the renderer is producing temp PNGs (/tmp/xxxx.png) and deleting them after upload.
  • With webhook + S3: Slack should display the image inline in the alert message.
  • With bot token: Slack should show the image in the main message, not as a reply in a thread.
Here are relevant snippets from our Helm chart values:
env:
  GF_UNIFIED_ALERTING_ENABLED: true
  GF_UNIFIED_ALERTING_SCREENSHOTS_CAPTURE: true
  GF_UNIFIED_ALERTING_SCREENSHOTS_CAPTURE_TIMEOUT: 30s
  GF_EXTERNAL_IMAGE_STORAGE_PROVIDER: s3
  GF_EXTERNAL_IMAGE_STORAGE_S3_BUCKET: grafana-image-rendering-prod
  GF_EXTERNAL_IMAGE_STORAGE_S3_REGION: us-east-1
grafana.ini:
  external_image_storage:
    provider: s3
    s3:
      bucket: grafana-image-rendering-prod
      region: us-east-1
  external_image_storage.s3:
    endpoint: s3.us-east-1.amazonaws.com
    region: us-east-1
  unified_alerting.screenshots:
    capture: true
    capture_timeout: 30s
    max_concurrent_screenshots: 10
    upload_external_image_storage: true
imageRenderer:
  enabled: true
  replicas: 1
  image:
    repository: grafana/grafana-image-renderer
    tag: 3.12.6
  env:
    BROWSER_TZ: Asia/Jerusalem
    RENDERING_ARGS: --no-sandbox,--disable-gpu,--window-size=1280x758
    RENDERING_MODE: reusable
Examples from renderer pod logs:
  • TimeoutError: Timeout error while performing step: panelsRendered
  • Invalid timezone ID: Asia/Jerusalem (fixed by encoding as Asia%2FJerusalem)
  • net::ERR_ABORTED on Prometheus queries during rendering
  • Deleting temporary file /tmp/<hash>.png after each render
**Questions for the community:
Why is Grafana together with S3 + webhook so flaky on my end?
  • Sometimes images upload to S3, and sometimes they don’t, with no consistency.
  • What am I missing here?
  • What do I need to make sure of when aiming to achieve said results?
  • For webhook + S3: Is there a supported way for Grafana to generate signed URLs instead of requiring a public bucket?
  • For bot token mode: Is there any way to make the image appear inline in the alert message rather than as a threaded reply?
  • For orgs that must block public access to S3, what’s the recommended approach to reliably send images to Slack?
