Hi
I was wondering if there is any appetite to add an image over the panel? For example. You can have the panel change colour depending on the thresholds. I was wondering if it possible to have an image go over the top of that in which it will could identify a particular thing.
For example an image of a server which if the panel below changes colour due to threshold it will show the image of that particular thing.
I was thinking that this could potentially be a modification of the singlestat, in which the image can be added there which could have a transparent background which would allow the threshold to change colour.
Thanks
