IE Time setting error
I tried version 6.5.1,
Still no time setting in IE.
Is there a way to set the time in IE?
The time picker not working in Internet Explorer is a known issue being tracked in the IE11 bugs issue grafana#15754. Since Grafana 6.0, Internet Explorer 11 is not officially supported anymore.
  • Internet Explorer 11 is only fully supported in Grafana versions prior v6.0.
from the installation/requirements documentation.
One workaround to the time picker is to set the time manually in the URL by appending the range to the parameters using something like &from=now-1440m&to=now.
Thank you very much.
